jmckelvy wrote:
I start closing the handle while watching the hole for the locks. Should be no resistance till about half the hole is obscured then finish snapping the handle to close. Adjust the length until you just start to compress the spring at the half way point just mentioned.
Ditto.
When I was at Torklift earlier this year, I asked them how to adjust. They told me exactly the above, which is what I had already been doing.
I also run the Fastguns with locks on 3 and the 4th one (front driver side) I use a quick release pin that came with the fastguns so I have easy access to the fuel door. (Fastgun blocks it)
