On my OFF-ROAD POPUP trailer I am going to use the Aluminum UNISTRUT angles and fasten them to the POPUP roof from the side panels. WIll not be any screws on the top of the roof...
I am wanting to mount either two 100W or 120W paanels on each side of my fanstatic fan in the fron and maybe a 240Watt panel betwen the air conditioner and the rear of the popup...
The nature of the UNISTRUT allows you to slide the panels and should be pretty easy to use. My panels may have to be installed after I raise my POPUP roof line and lock in place because of the added weight of the panels. My electric motor may not be able to raise the roof with the panels and heavy air conditioner on the roof...
Should look something like this...
Google images..
I can either mount the aluminum unistrut along the edge of the roof or use a bracket mounted to each side of the roof...
Just didn't want to drill thru the roof of my popup...
Still in the planning stage...
Roy Ken
King George VA
