ShinerBock
Aug 11, 2017Explorer
Perrysburg Dodgeboy wrote:
OK that is less the filter if you change your own oil and filter add 12 start it up and let it run for three minutes. Then shut it down and wait three minutes then check the oil. You are going to need to add some to bring it up to the full mark, should be just under a full qrt down.
Don
Nope! In fact, I just checked it while I was filling up this morning and it is right smack dab in the middle between the high and low marks in the safe zone on my dipstick just like it was when I changed it 12,000 miles ago. There is no need to bring it to the full mark unless you know you will be losing some oil. What matters is if you are between the high and low marks of the safe zone. At least with all the Cummins engines I have see on the dyno when I worked there or have personally owned.
Not sure how many 6.7L you have owned, but how many of them required you to add more oil than 12 qts?
