Grit_dog
Aug 12, 2022Trailblazer
At about $200 for a set of fender flares if you don't get some used or boneyard ones, I'd seriously consider having it color match bed-lined where the flares would go, to cover up your work and add very good protection....if you repair the rust properly.
Bonus, if you have damage that is or will be rusting on the rockers and bottom edges, you could prep those areas as well and have them sprayed.
If a big truck bed runs around $1000 to bed liner, including prep, I'd think you could get a little bit sprayed, already prepped and masked off by you for about the same $.
44,071 PostsLatest Activity: Aug 23, 2026
