- Ed_GeeExplorer III have a diesel powered Winnebago Fuse. The nozzles in the Truck filling pumps will not fit in the fuel fill port. I use the diesel pumps at the regular pumps.
- morphriderExplorerOnce you get the hang of it, fill up anywhere that's big enough to get your rig in. If a truck stop is easy enough for you, then yes, fill up there.
- gboppExplorerIf you use diesel you should be okay. It's usually diesel only at the truck fueling pumps.
44,031 PostsLatest Activity: May 21, 2025
