Npdchief07's avatar
Npdchief07
Filling up at gas station
New to towing and I get a little nervous. When I go to had up is it possible to go where the big trucks fill up at the larger gas stations??
  • I have a diesel powered Winnebago Fuse. The nozzles in the Truck filling pumps will not fit in the fuel fill port. I use the diesel pumps at the regular pumps.
  • Once you get the hang of it, fill up anywhere that's big enough to get your rig in. If a truck stop is easy enough for you, then yes, fill up there.
  • If you use diesel you should be okay. It's usually diesel only at the truck fueling pumps.
