philh's avatar
philh
Explorer III
Jun 02, 2019
FINALLY 1st trip in 192RBS
600 miles in multiple trips for service. Untold number of mods made on a brand new trailer.
What an almost perfect weekend. 1st site we parked at, besides being an absolute PITA to unhook from as the truck front wheels were 12" higher than the rear wheels, the post did not have 30 power available.
Also discovered, that not having a cover on the front vent was NOT a good ideal as the sun hit us in the face and woke us up.
Other than that, and a LOT of rain, we had a wonderful weekend. This really is a couples trailer.
  • philh's avatar
    philh
    Explorer III
    no 50 amp. There was 20 amp, but I was so frustrated at that point with the elevation issue, was happy to move :) They did fix it that evening, it was the breaker, it was broken.
  • Was there 50 amp power on the CG pedestal? I carry a 50-30 amp dogbone for that possibility. Also a 15-30 amp dogbone.
  • philh's avatar
    philh
    Explorer III
    jfkmk wrote:
    Must have been some slope if the front wheels were 12” above the back!
    When you buy a vent cover, get a dark colored one. I have the white on mine and, while I usually get up early, it gets bright in that trailer!
    Glad you like the 192RBS. We love ours!
    It wasn't so much slope, but move of a dip. Trailer was essentially on the same elevation as the rear tires, but the front tires elevated causing a problem with the power hitch foot barely clearing the ground, even though it was all the way retracted.
    Going with BLACK cover for the front vent.
    Last Train wrote:
    Be interested to hear of your service issues and mods you've had done. Hope you enjoy your rig as much as we have.
    Problems, been some stupid stuff, like I couldn't draw water from the onboard tank, and a DVD player that only played B&W. Dealer said, the filter was blocked on the water, which was absolute pure BS, they replaced the shut off valve, and in the process caused a dead quiet pump (through winterizing tube) to surge so bad I thought something was going to break. They claimed they changed a "setting" on the radio... sorry dudes, I already changed it, didn't make a difference. Picked it up, the 12V battery was completely and totally dead. Outer skylight has a deep scratch in it. Not sure when that happened, there's nothing in their lot, could have missed it during walk through.
    Changes... a LOT
    (2) 6V batteries
    Locking diamond plate battery box
    new battery charger (14.4V)
    External propane line with quick disconnect
    replaced grates in onboard grill (****, did that make a difference)
    locking bracket for propane tanks
    cable/chain support bracket
    colored LED light strip added to canopy roller. Currently working to allow that to be connected to 12V
    upgraded fan in bathroom
    wire shelving racks in every cabinet
    150 amp inverter (should have listened to an expert and gone with 300
    volt meter and 12v plug in entertainment center
    New 32" smart TV
    large hard drive and android player - still working to make this function like I want
    new 12v water pump (now supported vertically from a board under the sink, opening up a large storage area
    Large diameter PVC in pass through to hold load bars when they are not used
    quick drain valve on water tank.
    added bed cushion
    digital door lock
    easy start so AC can run off 2500w generator.
    I'm sure I've forgotten a few things, but got most of them.
    There's a pretty active coachman facebook page.
    X2 on the suggestion for the dark vent covers. My wife is really sensitive to early light waking her, so our pair of Maxxair smoke tinted vent covers were a great investment - and easy to install. Plus they allow for an additional source of air circulation - even while traveling down the road. And those vent covers have kept the interior dry even in heavy thunderstorms - like the one we endured in Santa Rosa, New Mexico just last Thursday.
    It's a couple's camper, for sure. But, on the other hand, we typically are quite fine with our typical 3 week+ trips for the two of us. It's been big enough for neither of us to have committed a major felony while on one of our camping adventures!
    But seriously, one of the advantages of the 192RBS is that it seems to strike a good balance between sufficient space for a couple's camper and yet small enough to offer very good maneuverability. For example, just the other day we arrived at our RV park in Red River, NM (just under 10,000' ASL), and it turned out that our reserved space required that I back through a tight area to get to our site - all due to a road closed for construction. That experience has been repeated in lots of tight fuel stops, as well.
  • Must have been some slope if the front wheels were 12” above the back!
    I can't imagine anyone suggesting otherwise. :p Our younger son slept a couple of times on the sofa but most often when he did decide to stay overnight he much preferred a tent. Last year we had friends visiting from Downunder and they too slept in a tent as there's just nowhere else inside a 192RBS for another couple. Great model couple's model though. :B
