Grit_dog
Feb 17, 2019Trailblazer
dave17352 wrote:
I would say that the location of that tank is higher than most rear end collisions with modern vehicles. It is not going to blow up like ten sticks of dynamite. If a gallon of gas was turned to a vapor at just the right mixture, then maybe. It certainly could cause a fire, if impacted and then a source of ignition was there. There is risk in lots of things we do, Like walking across the street or driving a RV.
Sure it will. Last time I doused a burn pile with a gallon of gas, it blew the logs and sticks into the next county and I found myself sittin on the roof of the house upside down 100yds away!
Oh wait, no it didn't. It was a big POOF only.
Dave you're right, if you vaporized and pressurized 1 gal of gas in a vessel, to the same degree it gets in a vehicle cylinder it would make a HUGE explosion. But since a plastic gas can can't do that, neither will the gasoline in it.
44,071 PostsLatest Activity: Aug 16, 2026
