jake2250 wrote:
Ok, after some research the Kumho 857 has some delamination issues also, the first review is from a travel trailer application in JULY of this year. The Hankook reviews are great for a VW van,, Cant find a tire near my size online. I can almost guarantee my 23 foot trailer is a tiny bit heavier than a VW van.. Thanks for the help.. I can see why No one would mount these on my trailer,, Maybe I can get a deal on Carlise or some GreenBalls...
A couple of points here for others who may be considering a tire like the Hankook or Kumho, setting aside how much your trailer weighs compared to a VW van, what is the load rating of these tires compared to the ST tire that is potentially being replaced ? Also what is the overall rolling diameter ?
For instance, in my case, going from a load range C, ST tire in a 205/75-14 to a load range D 185-14C ( Kumho 857 ), my load carrying capacity went UP 110 pounds per tire and the rolling diameter was 2/10" smaller ( 25.5" vs 25.7" ).
So in my case ( tandem axle ) I end up with a large margin of extra carrying capacity with the replacement tires. The measured tread width of the 185 vs the 205 was right at 1/2" narrower.
EDIT: also to the point that "no one would mount these on my trailer". That is simply not a factual statement. It may be fair to say that no one you have talked to will mount them.
Getting them mounted is no problem if a person goes to the right tire store. As I stated earlier, I have LT tires mounted at both a GoodYear store and a Ford dealer.
It sounds like the OP has made up his mind that ST tires are going to be his tire of choice, and that's certainly fine if that's his choice, but for others considering a swap, "there is another alternative".
