jimh406
Jul 12, 2021Explorer III
specta wrote:
Interpret things the way you want..
Obviously, that’s what you are doing even though links have been provided that the Utah agencies say otherwise. :D At this point, I’m pretty sure you are just pulling our leg.
Using your interpretation there is no limit for how much gray water you can dump, so a fiver with 100 gallons would be just fine. Or, if you carried hundreds of gallons of fresh to replenish your gray to dump that would be fine as well.
Also, it’s funny that you think we believe that you dig a hole big enough to hold your entire gray tank and redig if that hole won’t perc sit and let it drain, and you also bring something to compact with. I’m sure much of your dirt is as hard as ours come the dry season.
