Reddog1
Mar 13, 2017Explorer II
Wagonqueen Truckster wrote:My bet is if you call Stable Lift they will provide you with a second set of Saddle brackets. The catch is that the "Hoop" is adjusted to suit the Saddle brackets. This means both trucks must have the brackets in the same location, and located with the same preload. If this is not done, you will have to adjust the side to side tubing to align with the saddles and readjust the preload. Certainly doable, but with a bit of drama.
Fortunately both of my trucks are DRW and I did buy the lift for DRW. I just don't want to put the camper on my "new " Ram yet. Question for anyone. Since I will be putting the tie downs on the 99 Ford, do you think I can order another set for the Ram, so I can put the camper on either truck at any given time.
If you do not use the lift tiedown feature on a given truck, then no drama at all. Simply raise the hoop without the saddles, and use ýour typical tiedowns.
Wayne
