Reddog1
Mar 14, 2017Explorer II
burningman wrote:That will adjust the width for the bottom of the lift, but not the top. To adjust the top you would need to unbolt the lift from the TC, move the top out with new holes. A whole lot of drama. I think it much easier to make it wide enough for the widest truck.
... Failing that, the next best thing is to just re-adjust the Stable Lift for whichever truck it's on. You can remove your lock bolts, slide the tubing to the desired position, and drill a second hole and put the bolts back in. ...
Adjusting the hoop front to rear can be done as burningman posted, but still requires some work.
Wayne
