kehale's avatar
kehale
Finding 19.5" wheels
I'm looking for 19.5x6.75" wheels for a 2005+ Ford F550.
I'm planning on running 265/70R19.5 tires, but this requires a 6.75 or 7.5" wide wheel.
Does anyone know if they're being make anymore? I did see them a few years ago on an 05+ truck
Accuride 29879 are the correct side/spec for the inside rear, but I'd like to find the aluminum counterparts for the front and outside rears (polished inside/outside, as necessary)
  • Might Google the National Wheel and Rim Assoc.
    Check their member list for local retailers of high quality wheels.
    Be warned to steer clear of any non-standard wheel mfr's.
    The hwy speeds most RVs travel at require good quality wheels and tires.
    Cheap wheels, like cheap tires will get ya killed...
  • Someone posted a link to Alcoa, but Alcoa will not have what you are looking for. Which is probably why you posted, because you already checked all the usual suspects. Alcoa does not make a hub piloted wheel as wide as 6.75", nor as wide as the 7.50" that you'll need to have the correct shoulder support for 265's, with your hub pilot of 170.1mm and bolt circle diameter of 225 mm.
    Alcoa does make 19.5 x 6.75 and 19.5 x 7.50, but only in applications where the bolt circle diameter is larger, by 2 more inches (275 mm). There might be a good reason for that.
    The same holds true for Accuride. A poster above said something to the effect of "you should be able to find 6.75" aluminum wheels from Accuride as they were available for a Ford Class A chassis." To that I would ask, "Have you driven a Ford motorhome... lately?" Ford does not offer any aluminum wheels on their F53 chassis. Going back for the last 15 years, the F53 wheel availability has always been steel, not aluminum.
    The biggest you can go off the shelf are those 29879 Accuride steel F53 wheels at 6.75, in all positions, with a maximum width of 245 tire. That's still a huge, heavy, mileage robbing hunk of tire and wheel. Some of the 245'ss are speed limited to 65 mph. You can find some that are speed limited to 75 mph, but you will not find any that are speed rated to 81 mph as you can with the original 225's.
    (I have an F-550 also)
  • You should be able to find aluminum accuride 6.75 wheels as they were available on ford class a chassis...check rickson wheels also they have factory wheels..and they have chart for rim to tire sizing.. 265's I believe take 7.5's I was thinking of bigger tires myself to cut down the gearing..your later model should be easier to find wheels for
  • louiskathy wrote:
    I don't know what the specs would be to find what you are looking for but we found what we needed here Visionhttp://www.visionwheel.com/wheels.cfm?id=254
    If they don't have what you need... maybe they know who does.
    Might be worth a try HERE.
  • I don't know what the specs would be to find what you are looking for but we found what we needed here Visionhttp://www.visionwheel.com/wheels.cfm?id=254
