azrving
May 20, 2016Explorer
At HD it's called roto zip. It's used for drywall but would probably work on vinyl/plastics. The bit is like a drill but the end has a smooth area instead of the normal shape of a drill bit. When using on drywall the smooth area lets the bit slide along the edge of plastic electrical boxes without cutting the plastic.
I believe the bit is 1/8 inch diameter. It's the only way to go when working with drywall.
Bit
Bit
44,071 PostsLatest Activity: Sep 17, 2026
