rexlion
Feb 22, 2015Explorer
I've run 3 sets of Firestone Destinations on my tow vehicles, probably over 120,000 total miles, and have been happy with them. For the trailer, I'd say go for it... except for one thing. The 1000 lb hitch weight shows that the front trailer axle will be carrying more weight than the rear axle. So the weight will not be distributed evenly, and you need to calculate a bit more to ensure that the front TT tires won't be overloaded.
I will say that I've run mismatched tires on my trailers on many occasions and noticed no ill effects. You could probably run Goodyears on the front axle and Firestones on the rear if you wanted.
BTW, I looked at Tire Rack in the same size as the Firestones and found 2 tires with 2271 lb capacity... Kumho Road Venture AT KL78, a LT XL tire, and another XL tire called Fuzion SUV... the latter is only $73 each.
44,066 PostsLatest Activity: May 18, 2026
