rhagfo wrote:
Grit dog wrote:
nano wrote:
I just want to make sure I don't set them too low.
The ole biscuits numbers are about right. I run the same +\- but will go lower in the winter if running ice and snow all the time unloaded. Your dealer is full of shiiiiii....., BUT with TPMS and a 2500 you will get the tire light if you lower the tires below the preset threshold. It's around 65F/75R psi based on the 2014 models I've had. Yours may still have the light load feature to temporarily lower the threshold. But even that is too high for empty driving iirc.
2 options, lower pressure and live with the idiot light or find a dealer or shop with witech software and change the TPMS thresholds.
You will not hurt anything running with the light on, nor will you hurt anything down to about 40/30 psi for normal unloaded driving. Noting optimum pressure is a bit higher.
X3 Old Biscuits thoughts, not only better wear, but far better traction in rain and snow.
I also don't run 80 psi in the rear loaded as I would have 6,830# of capacity, and only carrying about 5,500# of weight on the rear axle, between 65 and 70 psi.
My 17" tires are rated at 3195#/80psi. I run 80psi cause I am towing heavy...right at rear tire max load rating
