Tvov wrote:
So... if I go to a car dealer to replace tires (sometimes they have really good deals), and the guy there asks if I want the same tires that came with the car new, are those going to be the faster wearing OEM tires? Or "normal" tires of the same brand and model? Or would it depend on the dealer?
There are 3 possibilities:
1) If you have a GM car and it is still within 3 years since the tire was supplied to GM, it is very, very likely that the tire would be identical to what was supplied originally. You can tell because the tire will have the TPC number on it.
2) The tire is still being supplied to the OEM and the tire manufacturer doesn't produce an aftermarket version under the same make and model (I only know of one tire manufacturer who does that), then you'll be getting the OEM version.
3) The tire is no longer supplied to the OEM, then you'll get the aftermarket version.
