jimh406
Jun 20, 2022Explorer III
It all depends on how close to being overweight you are and how big your holding tank are. My Host holds 60 gallons of Fresh. When I hauled on my SRW, I tended to only put 10-15 gallons in if I knew water was available where I was going. Since water weighs 8.3 lbs a gallon, my full tank was around 500 lbs. I saved a few hundred lbs by not filing it all of the way up.
In my DRW, the water weight isn't significant, so I usually am full before I go anywhere. If you have a small freshwater tank, it probably doesn't matter much.
One more thing, I found the handling remarkably different with full grey/blank tanks on the SRW, so I tried to keep the holding tanks emptied before very much interstate driving.
