Seattle_Lion's avatar
Seattle_Lion
First RV trip ever! Trip report
My first posting here was about the massive plumbing leaks (four out of ten fitting failed) on my 2014 Kodiak. Our first trip was scheduled for last Wednesday returning on Saturday. The TT was ready at the dealer on Tuesday afternoon (cutting things very close). We picked it up and took it home. That sounds simple, but we are new at this. My wife has towed a TT before, so she drove. Happily, all went smoothly. The weight distributing, anti-sway hitch did its job. Her new Ford F150 with Eco-Boost had no trouble with the TT (27ft, 279RBSL).
We set off on Wednesday after work. Our first trip was to Leavenworth, WA, about 120 miles from home (I figured that my AAA RV membership would be able to tow us home at no charge if things got bad). We stayed at a very nice KOA campground.
Since this was my first experience with an RV and a RV campground, I had visions of screaming kids, battery-stealing maniacs, and people who were like Chevy Chase in the National Lampoon Vacation series. Happily, this campground was peaceful, well maintained, and populated with a nice mix of good people in RV's, tents, and small cabins.
There was a wide range of RV's ranging from big pushers to a pickup with a cap that served as the camper to a nice, retired couple. My wife did a good job backing into the site (if you overlook that she nearly took out a lamp post). She recovered without damaging anything and we set up the TT.
Setup was surprisingly easy. My handy 18v drill handled the stabilizing jacks with no problem. Power and water connections were easy. Sewer was a bit of a problem. Our 20ft hose was stretched to the limit to reach the waste fitting. I noticed that the TT next to us (about our size) was not connected to sewer at all. It turned out that he only had a 15ft waste line. Before he left, he pulled up and used his shorter line to clean out his tanks. Is this sort of run typical? Do I need to find a longer, better, line? Last, I connected the campground cable TV to our TT and we were set.
The plumbing worked perfectly. There was enough hot water for a good shower and the kitchen, AC, and toilet worked perfectly. The TT itself is very comfortable with only one problem: I am 6'2" and the bed is a "short" queen. My feet stuck out over the end. This was unexpected. By the 2nd night I managed to sleep.
Each day we took a trip to something new. We visited Grand Coolee Dam and Lake Chelan, not to mention a wonderful German dinner in Leavenworth.
The ride home was fine with only one exception. While on I90 the F150 towing package warned of excessive sway. It only happened once and there was no apparent cause. Also on the way home, we had a slight bathroom emergency. My wife needed to pee badly. We pulled off the road, opened a slide a bit so she could get in to the bathroom, and all was fine. I had no water in our fresh water tank, but there was enough left in the pipes to seal the toilet when she was done. Note to self: keep some water in the fresh water tank for just such needs.
Dumping the tanks was simple and easy. One question: what is the best product for the black water tank?
After a terrible introduction to RV'ing, our first trip was truly fun. I am hooked. Next weekend we are off to Cape Disappointment, which according to Sunset Magazine is the best campground in the West.
Thanks for all the help and encouragement. Once I get used to sleeping with my feet off the bed, this will be the greatest way to travel I have ever tried.
Bob
  • Glad to hear the trip was pretty much problem free. That's the way it's suppose to happen.
    At every park we've stayed the water, sewer and electric were all within a few feet of one another so I've never had any issues with the water or sewer hose not easily reaching the appropriate connection.
    So far we've had nothing but good experiences with the people we have met at the campgrounds (NY, PA, VA, SC and FL).
    I'll usually keep a few gallons of water in the fresh water tank to use in case we need to pull off for an emergency bathroom break. At this point (1 year into our RV experience) I can't make a recommendation on how to keep the black tank in good condition other than what my dealer told me, people tend to use too LITTLE water when they flush so use more and put a couple of gallons of water in the black tank and drop in a Porta-Pak at the end of a trip.
  • rightyouareken wrote:
    By the way, I'd recommend spending some time adjusting your hitch setup. Having the trucks sway control feature is worrying. I've never had mine kick in and I've been blown around by some pretty strong winds on occasion. Yours must have been a doozy!
    It was on the way down from Snoqualmie Pass. It was windy. It must have been a big gust. Since we experienced no other issue, I decided not to tighten the anti-sway more...but then we really don't know what we are doing.
    Bob
  • By the way, I'd recommend spending some time adjusting your hitch setup. Having the trucks sway control feature is worrying. I've never had mine kick in and I've been blown around by some pretty strong winds on occasion. Yours must have been a doozy!
  • We use Camco TST RV Toilet Treatment (green not blue). We buy the large bottle at Walmart, but they do have smaller bottles that don't weigh as much. Note: Use 2x as much in hot weather. We use the grey tank deodorizer too. You can use Lysol lemon cleaner instead. Grey tank can smell worse than the black! Yes, you will need a longer sewer hose. Search this forum for solutions to the short bed problem. Some people put a piece of foam at the head of the bed once they get set up, to give a bit more length. Most of the campgrounds we visit are quiet and peaceful except on holidays. We usually research them on www.rvparkreviews.com and only a couple of times have we felt it necessary to report someone to the manager or ranger. Enjoy your travels and keep us posted!
  • We carry 20 ft of sewer hose, but very seldom need more than 10 feet. When pulling into a site, I try to get close to the sewer connection. We carry 35 feet of potable water hose (25 ft plus 10 ft), as I would rather use more water hose than sewer hose.
  • Congrats on the successful trip! We stayed at Lincoln Rock state park near Wenatchee the weekend before the 4th, and also visited Chelan and Grand Coulee Dam. Enjoy your upcoming trip!
  • ScottG wrote:
    BTW, what CG did you go to? There are several super nice ones in the area.
    Scott
    We went to Pine Village KOA. It was clean, friendly, and quiet.
  • Sounds like a great trip. FWIW, I don't generally even connect the black tank hose until we're ready to leave. Why handle it twice!
    Scott
