bigorange
May 30, 2020Explorer
Boon Docker wrote:
Be sure to open a hot faucet before removing the water heater plug. There could be a lot of pressure there if you don't open a faucet first.
You can also open the pressure relief valve on the water heater. Been there, done that and took a blast of hot water to the gut from a pressurized tank.
Also, if your tank has a little on/off toggle switch for electric on the tank itself, make sure that’s turned off before draining so you don’t burn out your element.
