rvshrinker
May 31, 2020Explorer III
i’m going to call the dealer and see if he can tell me for sure, as I can’t see any way to open those valves from the inside. They come up through the bathroom sink cabinet.
I did drain my whole system including the hot water heater tank. The anode rod is slightly pitted, a bit more at the neck, but no rust and seems good enough to put back in (it’s 2.5 years old). I’m reading conflicting info about whether the anode rod should be kept wet or dry when not in use; manufacturer seems to suggest draining the tank when not in use for extended time, others say don’t let it dry out.
44,070 PostsLatest Activity: Sep 18, 2026
