rvshrinker
Jun 04, 2020Explorer III
Grit dog wrote:
Chlorine disappears basically 4 ways. Time, UV / air exposure, chemical neutralization or dilution.
Since the system is not really exposed to open air and sunlight, you can either wait, use dechlorination tabs (sodium sulphate, vitamin C , etc) or dilute it.
When disinfecting pipelines I use dechlorination tabs.
Small quantity like a Camper water tank, just fill and drain a couple times.
FWIW, google is your friend here. You can learn a lot about this with a little research.
i figure it was 50 ppm when sanitizing, i drained it all out, so if there’s less than a gallon left in my 80 gallon tank it would be diluted to 100:1, which is 0.5 ppm, probably about the same as municipal water. so i guess i’m done.
i guess if it tastes too much like chlorine in a week or so i’ll drain it one more time.
44,070 PostsLatest Activity: Sep 18, 2026
