DutchmenSport
Oct 30, 2017Explorer
oyarsa wrote:
I was debating going back with antifreeze, but I don't like the idea of having to flush it all out in less than two weeks. May be better safe than sorry...
Suggestions of where the water pump may be hiding? It's annoying that all I got was a generic Keystones manual and not a model specific manual.
I looked at your floor plan on-line. Does yours have a laundry chute on the drivers side beside the bed? If so, look on the passenger side for that same covered box. More than likely, it's under that box. You have to remove the top, under the carpet.
If you do not have the laundry chute, then it's probably under that box on the driver side. Keystone love to put the water pump there for some reason, and then make it a challenge to reach it.
Turn the water on, listen for the pump to run, and you'll find it.
Also, if it is under that boxed area, under the carpet, you'll need to raise the master bed to open it.
After you figure how it opens, take a moment to drill a hole in the lid and attach a kitchen cabinet door knob so the next time it's easier to open.
