vlopddap's avatar
vlopddap
First TT owner... have a few questions!
Well, I first thinking to start a few thread to ask a few question in specific section of this forum, then I decided to combine all my small questions/concern into a single thread since it's my first TT ever and I purchase it slightly used, I have a few technical questions, most will be very quick to answer like "yes it's normal and blablabla".
As stated in my signature, my TT is a slightly used 2011 KZ Sportsmen Classic 16BH. The former owner used the trailer like 6 times on campgrounds but the unit is still 3 years old.
Question #1 : No 12V fridge...???? In my previous Rockwood pop-ups camper I got a 3-way fridge (12V, 120V, gas) before leaving home, I fill up the fridge with food, then switch the fridge on 12V when I'm travelling. When I reach campground (sometime after 5-6 hours travel), food is still cold and then I switch the fridge on 120V. Big surprise to discover that my new trailer only has a 2-way fridge (gas & 120V). Even the new 2014 still have 2-ways... So how do I keep my food cold while I'm traveling? Is it safe to open the gas burner when the trailer is in motion?
Question #2 : Aluminium kinky roof, grime, black strikes.. Another big surpris is to see the aluminium roof kinky everywhere and where there's several spots where there's stagnant water after each rain (when trailer is levelled). So every rains the entire trailer is covered with brown/black strikes coming from the roof. I tried to clean the roof with a brush and car soap and even after that, there's still brown/black strikes all over the trailer after raining! Moreover the roof caulk is still in good shape (no leak, not dried), but it's all greenish/blackish... disgusting! What's the options?? Clean black strikes with bleach cleaner after each rain????!!!! Kinky roof is not an issue apparently because my father-in-law own a 2013 (1yr old) Sportsmen and his roof is kinkier than mine!
Question #3 : Any suggestion to run speakers wire inside walls/roof to install exterior speakers? Cause my 16BH came with a interior sound-system from factory (Jensen radio with speaker switch) but no exterior speaker installed... very sad! Is there a way to run wires inside wall or roof inside a travel trailer or everything is pretty sealed with urethane foam?
Question #4 : Propane smell around exterior tank, even when everything is closed. I'm just wondering if it's normal to have a slight propane smell around the front tanks (I have a dual 20 pounds system on mine). Even when tanks valve are closed, there's a slight smell because propane actually smell rotten eggs. I ran the soapy water test and don't see any leak. But in fact even with two tanks valve closed, there's still a slight smell. Is it normal?
Thank you very much for your advices!!
  • re: propane odor, you shouldn't have any odor. I had the same issue on my last trailer. The smell was inconsistent and I couldn't find the leak using soap and water on all connections. It turned out the propane lines between the tank and the three-way valve were bad where the connectors crimped on. They didn't leak all the time...just occasionally. I found it when I bumped one and it leaked a little burst of propane. I replaced those lines and my problem was solved.
  • old guy wrote:
    while traveling many leave their frig running on propane. I for one do not. the RV guys like the RV Doctor and Rv 101 guys say no do not travel with the frig running.
    :h
    My advice is to read up on what those two guys actually say about this subject.
    RV Doctor/ Propane fridge........RV 101 /propane appliances
    Probably 90% of RVers run their fridges on propane while traveling. Former concerns associated with potential propane-associated fires have largely been remediated by improvements in tank design/fitment. I think it prudent to turn fridge/any other gas appliances off when refueling the tow vehicle. There's a discussion going on around that point at this link.
    That said:
    If you really want to run your fridge off 12v while traveling, an inverter aboard the trailer will change 12v to 120v power usable by the fridge.
  • while traveling many leave their frig running on propane. I for one do not. the RV guys like the RV Doctor and Rv 101 guys say no do not travel with the frig running. I use reusable ice packs in the frig to keep my food cold and fresh. when I get to can and hook up I place the ice packs in the freezer to refreeze.
