On my way back from New Orleans I had a flat tire on the T.T. I was not able to take the lugs off ,so I call for service. They sent someone, he took the flat tire off and replaced it with the spare. H...
The lug nuts need to be re-torqued after the wheel is changed out. I bet that there is a warning sticker somewhere around your wheel wells that tells you to retighten the lug nuts a couple of times.
A good torque wrench is very important to make sure your lug nuts are properly installed.
