On my way back from New Orleans I had a flat tire on the T.T. I was not able to take the lugs off ,so I call for service. They sent someone, he took the flat tire off and replaced it with the spare. H...
Unless they use a torque wrench to tighten I go behind and usually try and loosen as usually they put them on so tight it' almost impossible to get them off. OP, as others have said...the buck stops with YOU,
