In the unlikely event of a flat tire, what has been found to be the safest way to get the trailer up? I have a dual axle Open Range weighing in at aprox 5000 lb. I have my truck jack and a 12000 lb b...
I use a floor jack with some stacked 2x4s if lifting the entire trailer by the frame for major work. HF 12 ton jack stands are plenty tall to go under the frame. This stuff does not go on the road.
As for tipping there is virtually none when I raise the tire 1/2" with a bottle jack on the axle to swap wheels.
