Itchey Feet wrote:
I load and unload ours with extensions ( front only) to get jacks outside the dully wheels. I built my own out of channel iron. Is the camper you have setup for a (3) or (4) jack lift? Would be harder w/(3) jack system. Have you thought about building a rack that has rollers on it that could be used to (back up to) and roll it onto the flatbed? There is a picture of ours if you go to my profile, second picture
Thanks for your response itchey feet! The camper has a 4 jack system, but the passenger rear jack has been ripped out of the framing & would need to be repaired if I wanted it to be functional. But since the jacks don't do much good when loading on a flatbed truck or a trailer, not sure if it is worth repairing. I just need to figure out a way to get it lifted & just drive under it without the use of jacks.
