northshore's avatar
northshore
Fleetwood, Elk Horn 9T Short bed truck?
I've got a 1999 f250 super duty 7.3 diesel short bed extended cab pickup. I am looking for a cabover camper, my bed is 6'6" and with the tail gate down its 8'6" and have found this camper for sale locally;
1999 Fleetwood, Elk Horn 9T
the guy says it weighs 2300 lbs wet
I would like opinions about the compatibility of the two, is the camper just too long, too heavy or any other potential problems?
  • I've got a 1999 f250 super duty 7.3 diesel short bed extended cab pickup. I am looking for a cabover camper, my bed is 6'6" and with the tail gate down its 8'6" and have found this camper for sale locally;
    Being a previous Elkhorn owner (2000 10V) the weights you were cited are probably low. Mine was minimum of 3000 pounds and upwards of nearly 4000 when fully loaded. Also, check for water leaks as the Fleetwood campers were notorious for leaking especially in the rear just under the roof. Run, don't walk, from this camper if it has had a leak. You did not share any prices but I would guess if it is in perfect shape that it could bring $2500-3500. More than that and I would walk. I had mine on a Ram 3500 dually and it still needed air bags and overload spring bumpers to adequately carry the camper.
  • Most TCs require removal of the tailgate. Even if you can leave the tailgate down, it really cannot support much weight and rocks will beat it up pretty quick.
    Your primary concern is the Center of Gravity (COG). Very bad idea if it is behind the rear axle. Easy to tell. With no TC, measure from the front wheel wells to the ground. Do the same in the rear. Load the TC and remeasure. The front and rear both should measure less. If the front is the same or more, the COG is behind the axle. Not good, the steering will be bad.
    I really question the COG being acceptable with a short box and a 8-foot plus long TC, unless the TC is designed for a short bed.
    Wayne
