- SidecarFlipExplorer III
Kayteg1 wrote:
My 2002 Fletwood Caribou does have aluminium frame.
But it is skeleton frame only, when lot of structural beams are wood only.
As I "experienced" there is no aluminium in generator box frame, mounted in rear wing.
If you have a chance to see it, open refrigerator inspection door and with good flashlight and mirror see around the corner.
You should see aluminium if it is there.
I also have "aluminum frame" sticker on the rear.
You also have some 'nasty wood' per your pictures... and...
Your climate is a lot different than up here in Michigan. - Kayteg1Explorer IIMy 2002 Fletwood Caribou does have aluminium frame.
I also have "aluminum frame" sticker on the rear. - SidecarFlipExplorer IIII did real quick from the NATCOA forum It's wood frame construction
Goggle it up. One of the posters there posted the cut away brochute.
Conversely, my comment again will be...
If it's in Michigan with our weather extremes and it is outside and the owner did not maintain the caulk and seals, at that age, it's probably well on it's way to a rotten frame and mold.
Might be a nice winter project, then again, it might be landfill material.
44,028 PostsLatest Activity: Mar 27, 2025
