work2much
Jan 06, 2018Explorer
A perimeter bead of dicor would probably keep a flexible panel down. Although it's not fun to remove you could certainly remove a panel later. Either that or eternabond tape around the edges. Later just cut the panel loose and leave the tape on the roof.
600 Watts should be very doable on your 1160. You could probably get 900 or more.
44,066 PostsLatest Activity: Mar 14, 2015
