All, I am looking at flipping my axles on my 1989 Fleetwood Taurus trailer. I found a place that does them at a good price. I have read some negative things online about more sway and braking is...
An axle has a slight bow to it. If you look carefully from the rear you can probably see that is higher in the center than at the ends. Appears to be bent. That is normal and should look the same after the axle is moved below the springs.
