All, I am looking at flipping my axles on my 1989 Fleetwood Taurus trailer. I found a place that does them at a good price. I have read some negative things online about more sway and braking is...
@BB_TX: That's interesting. I will have to look when I get a chance. So...if it's bowed..then that would explain why you can't rotate it 180 degrees and reuse the original part that's weld onto the axle. There for the new part is weld 180 degrees and the axle remains in the same place it originally was mounted. Really - the only reason to remove the axles is to perform the welding I would think.
