cs2kplus's avatar
cs2kplus
Flipping Axles
All,
I am looking at flipping my axles on my 1989 Fleetwood Taurus trailer. I found a place that does them at a good price.
I have read some negative things online about more sway and braking issues.
Also, this:
Before You Flip Your Axles, Consider This
The axles on your trailer come with a pre-existing camber (a vertical upward kink/bend in the axle center).
This camber allows the axle to flex with the weight of the trailer, and run with the tires square and true to the road.
Without camber, the weight of the trailer would force the tires to run unevenly on the road, causing premature tire wear, poor trailer tracking and damage to the running gear.
I don't know what this means.
Looking for some good advice on this.
Wayne
  • It means that you DO NOT actually flip the axles, you simply move them from above the spring to below the spring. New spring mounts will need to be welded on to accomplish this.
