eHoefler wrote:
Redterpos3 wrote:
720Deere wrote:
A heavy duty battery charger will power it just fine too. You can crimp terminal ends on your wires so you have something to get a bite on with the jumper cables, but honestly if you are close enough to the battery to use jumpers, just add more heavy gauge wire to the pump leads so you don't have to deal with jumper cables.
Ah, I've got one of those!! I'll start with that, and look into the heavy gauge leads also. Do I need to put an inline fuse when using the battery charger?
No it won't. I started out that way and found that it had a severe voltage drop and the pump ran slow and way to hot. I wound up using a 30 power supply I had on the shelf. The pump ran faster and did not overheat with out any voltage drop.
I think you missed the HEAVY DUTY part. I have run my pump with my 60 amp charger/200 amp booster and it runs the pump fine with no voltage drop. A 20 amp or smaller charger will not work. The 20 amp setting on my big charger allows the volts to drop to just over 11 volts. Sorry I didn't post more detail originally.
