rode2nowhere
Oct 24, 2013Explorer
flojet pump will not pump
2011 keystone sprinter, tried to winterize, flojet pump runs but no suction. I put a bypass in line at the pump last winter to suck the antifreeze into the pump and through the lines, this year will not pump. it has not been used for 6 weeks or more. I tried putting a funnel on the bypass hose to try and prime the pump and nothing. I am assuming yhe flojet pump died, is there anything I can do to it to repair? And what are my other options here to drain the lines, I have no access to air pressure to blow them out, nearest rv placed is over an hour away, it has pex tubing and fittings. Appreciate any help?
