Old-Biscuit wrote:
Sounds like bathroom sink drains into black tank and you overfilled it which then leaked out from toilet....either around floor flange gasket or toilet pedestal
Leaving faucet trickle is not a good idea to begin with.
Furnace running/maintaining a comfortable temp inside rv works.
Opening lower cabinet doors at night helps increase warm air circulation around pipes
IF you can't keep trailer plumbing above freezing then drain system
Absolutely correct. Any person living in the west can tell you even waterfalls and moving bodies of water can freeze. That water trickle not freezing is a myth.
