NanciL wrote:
WyoTraveler wrote:
Old-Biscuit wrote:
Sounds like bathroom sink drains into black tank and you overfilled it which then leaked out from toilet....either around floor flange gasket or toilet pedestal
Leaving faucet trickle is not a good idea to begin with.
Furnace running/maintaining a comfortable temp inside rv works.
Opening lower cabinet doors at night helps increase warm air circulation around pipes
IF you can't keep trailer plumbing above freezing then drain system
Absolutely correct. Any person living in the west can tell you even waterfalls and moving bodies of water can freeze. That water trickle not freezing is a myth.
You might want to tell my spring water at elevation 3200 feet that.
Any time the temperature is below 26 degrees with a high wind, I open the bathroom shower faucet and let a little stream of water run.
I have the plug out of the trap and have it piped out to the side of the cabin. Many nights and days it is below zero with wind chills way below that and it never freezes. If I didn't do that the pipe coming down from the spring would freeze solid.
It is the same principal and is not a myth
Jack L
jack L
Your spring water comes out of the ground well above freezing--probably no less than 40 degrees--so keeping it running keeps relatively warm water moving through the pipe.
Before water can freeze, it has to get down to 32 degrees and THEN lose a lot more heat to make the phase change from liquid to solid.
