mobeewan
May 23, 2018Explorer
Me neither, I'm 5-10 and 320. Bed & dinette are fine, although I did have to re connect a wavy spring under the jack knife sofa. It's pretty cheaply made. An automible seat with similar spring design is way better. I'm going to rebuild it as a bench seat with cushions. Accessing stored things underneath will be much easier.
I thought I found a soft spot from water damage in the floor and it turned out to be a seam between 2 pieces of plywood in the flooring passing over the heat duct about 12 inches where the plywood is unsupported. I haven't fell through yet. I can feel it flex a little when I step there. It's 3/4 inch plywood so I'm not real worried about it.
44,066 PostsLatest Activity: Jul 25, 2018
