kirklu's avatar
kirklu
Fluctuating 120vac in TT
I am having a problem with the 120vac. My trailer is plugged into an ac outlet at my house. I went in the trailer today preparing for a trip. I turned a couple of lights on and after a few minutes the lights started going dim and bright every few seconds. The plug in volt meter in one of the ac outlets was jumping up and down. Nothing else was turned on. I went to the fuse box and could hear it humming and clicking with the fluctuations. When I turned off the ac breaker that said services it stopped. I replaced the breaker but the problem did not go away. Any ideas?
  • Most likely the charge circuit in the converter cycling. You could have a battery going bad.
