Wind_River's avatar
Wind_River
Foam in tires
Has anyone heard of or have foam sprayed in your TT tires? Dealer convinced a friend of mine this is the way to go because he will never have a flat tire.
  • In the dirt bike world, it's called a Bib Mousse. Never thought about something like that for a trailer tire, and I've had many blowouts with ST tires.
  • I put Nitrogen in my tires every time I add air. For those of you who don't know, regular normal every day air that you breath and put in tires and pool toys and anything else is 78% Nitrogen
  • Back when I worked construction our skidsteers and UTVs all ran foam tires. I couldn't imagine the rough ride going down the road on a set of rocks.
  • At my scrap facility we ran foam fille tires, in loaders and rock trucks, that never exceeded 30 mph.
    Is that how you drive?
  • I had the same initial reaction as carringb. I too didn't think you could use foam filled tires on highway speed tires. I do know on a UTV they prevent flats but, give a very rough ride as the tires are very unforgiving of logs, bumps, rocks, Etc.
  • Foam filled tires can't be used on the highway. If he's looking to foam-fill a construction trailer that doesn't see highway speeds, then it's possible.
  • Forget anything a dealer tells you that isn't written down in legalese.
    Ask a pro tire guy what he thinks of that idea (mine cusses if I bring up the subject).
    And Bumpyroad, I horselaugh at the people selling N for tires. "but the O will leak out and the N wont!" sez they. Well since we all start with 80% N anyway, why not just refill when that pesky O leaks out and youll have almost 100% N eventually anyway. Duh.
    Science Matters.
  • Tire manufacturers wouldn’t recommend this if it worked? How much did the dealer charge for this snake oil?
  • I'll sell him some Nitrogen to put in them so he will be safer.
    bumpy
