Bedlam
May 02, 2013Moderator
The ScanGuage II can only display data coming across the OBD port. If you want additional parameters like EGT or fuel pressure, you will need to add more senders and gauges.
The SG II did take some time to program with vehicle specific parameters, but once stored does not need to be done again. I would prefer a cycling mode to watch more than four parameters without interaction and graphic color gauges are quicker to read than numbers, but this gauge does everything I need for a reasonable price and can easily be moved between vehicles (enough memory to store my VW and Ford parameter information at the same time).
44,071 PostsLatest Activity: Sep 17, 2026
