dvick wrote:
dvick wrote:
Turtle n Peeps wrote:
When you changed the oil did you reset the OLM puter? If not you should do so ASAP.
No, I was wondering about that.. I need to figure out how though. Do you know?
dv
Yeah you're probably right. Eating the expense now is better than problems down the road.
dv
Follow this to reset:
To reset the oil monitoring system to 100% after each oil change, perform the following:
1. Press and release the SETUP button to display "OIL LIFE XXX% HOLD RESET = NEW"
2. Press and hold the RESET button for two seconds and release to reset the oil life to 100%.
Note: To change oil life 100% value to another value, proceed to Step 3.
3. Once "OIL LIFE SET TO XXX%" is displayed, release and press the RESET button to change the oil life start value. Each release and press will reduce the value by 10%
