The Mad Norsky wrote:
CREATO wrote:
skyhammer wrote:
That is not the way my 2011,6.7 diesel reset works, it is nothing like you described.
First there is no % reading of oil life. It is either OK, or it warns you that you need to change the oil soon.
Basically you navigate via the steering wheel controls to "information, press OK, select "system check", press OK. Then all it tells you is that the oil is OK or it is time to change. When the oil is changed press and hold OK and a reset line will appear. When it resets, it says OK.
Best bet for the OP is to download the manual from Ford.
x2 thats how mine works as well
X 3. Mine also works this way. No percentages shown.
Taken dirrectly from page 26 of the OM.
See link RedRocket posted. This is where the info posted came from.
