Old-Biscuit
Jan 16, 2016Explorer III
rhagfo wrote:Old-Biscuit wrote:M.R.E. wrote:
I now have a Columbus 340RK, loaded about 12,400, pulls great. With the Cougar I averaged 11.9 mph towing from MI to FL. I had no problems in the Mountains.I have only 104,000 on it.Excellent condition, I'll probably keep it.
Have you been across a set of scales with the old Cougar or more importantly with this Columbus?
You have a 2002 F250
At least it has the camper pkg and trans cooler.....and an exhaust brake
2002 F20...GVWR 8800#
With the camper pkg (like F350 GVWR 9900#)
Max tow rating is 13K but payload is low.......1440#/F250 2700/F350
You will be over GVWR (regardless of which figure you use F250 or F350)
RAWR...should be right at rating.
That 5vr is max for your truck.
7.3L is a good strong motor
All us early 250/2500 Camper Package owners are well aware of the "Limitations" of our TV, we have told them (The TV) they can't carry that much, but they just don't listen! :S
I am very happy with the way my 2500 handles our 11,000#+ 5er, another 1,000# would not make much difference.
While the OP is over the rated GVWR, he is still likely under tire and axle ratings.
The OP's Profile has a tuner listed, and an Exhaust Brake, but no air bags, likely not needed.
Camper pkg. makes it a F350 w/o the badge and stickered GVWR
Suggestion to go across scales is for OPs Information
44,056 PostsLatest Activity: May 04, 2014
