- wilber1Explorer
valhalla360 wrote:
Even if it dents easier, at least it won't rust away.
Yeah, if you use the bed really hard that's not great but put a bed liner or a sheet of 1/2" plywood in the bottom and throwing cement blocks in the back is not an issue.
Pure aluminum is quite corrosion resistant but alloys aren't. Alloy manufacturers often put a thin layer of pure aluminum on top of the alloy for corrosion resistance, called Alclad. Even so, float planes in salt water are a continuous battle against corrosion. Still, more manufacturers will be using more aluminum. Land Rover has been using it for bodies since the forties, believe it or not because there was a steel shortage in post war Britain and they have been using aluminum ever since. - TrackrigExplorer II
Yes, I've always had a sheet of plywood in my truck bed. Sometimes in the winter I put in a piece of plate steel also.
The new F450 truck next year will have a flat bed on it though because they've jacked the standard pick up beds too high.
Bill - valhalla360NavigatorEven if it dents easier, at least it won't rust away.
Yeah, if you use the bed really hard that's not great but put a bed liner or a sheet of 1/2" plywood in the bottom and throwing cement blocks in the back is not an issue. - hone_eagleExplorer
Me Again wrote:
hone eagle wrote:
Well GM is about to go aluminum ,hope they fix all the mistakes Ford made and do it right.
With a metal floor in the bed! Now we have the issue of dis-similar metals.
The marine industry solved this in the '80s,most ultra luxury yachts were steel hulls and alloy superstructure, and in a salt water environment . - Me_AgainExplorer III
With a metal floor in the bed! Now we have the issue of dis-similar metals. - SamsonsworldExplorerIt is a non-issue.
- hone_eagleExplorerWell GM is about to go aluminum ,hope they fix all the mistakes Ford made and do it right.
- HammerboyExplorerWell let's talk about it anyway, Seen a couple videos on YouTube from Big Truck Big RV I believe where they did in experiment tearing the metal on a aluminum Ford and a steel Chevy I believe. I was amazed how easy the aluminum tor in comparison to the steel. Ford owners, what has been your experience with dents and such?
Dan - DutchmenSportExplorerToo bad, this was bound to be a great topic discussion.
44,051 PostsLatest Activity: Sep 25, 2025
