Garry_Gayle's avatar
Garry_Gayle
Ford Dealers
I am getting a P0088 Code in my 08 6.4 with severely reduced power, does anybody have a Ford Dealer Recommendation in Las Vegas, NV, currently at the Oasis RV Park
  • See if you can get this addressed as a warranty issue that was not properly diagnosed the first time. They should be able to pull up your warranty work and verify you had it in for repair for the same problem.
  • I had this repaired last Oct in Elkhart, IN by the local Ford Dealer under warranty which was a computer patch that was supposed to take care of the issue. Now it's my dime
  • Can't help you with a dealer but.. P0088 Fuel rail/System Pressure-Too High
    Worse case could be a high pressure fuel pump. If replacement is required, cab has to come off.
    Hopefully it's not this...try clearing the code and see if it comes back on.
    Good luck with it.
