stripit wrote:
Have new valve stems installed on the inside wheel that protrude out and through the holes in the outside wheel. No longer a job you will hate to do, and you could even install a tire pressure monitor sender without any problems. If the tire store doesn't have the right stem, go to a truck tire store and they should have all kinds of them with the length and angle you need.
The tire place I am using does a ton of Box Vans and RV's so hopefully they will have the stems your talking about. Only neg is wont be able to rotate after doing this.
