stickdog wrote:
A couple things: first there is a known problem with the TPMS on the 2017 Ford DRW's with corrosion. There is a thread on a ford fourm about it. I had one go bad on my 2017 replaced with a non TPMS as they were back ordered. Only reason they were back ordered was they can't keep them in stock.
Second I couldn't get my rear hubcap even tried the ratchet straps wound up ordering hubcap removal tool still had to remove the rubber mallet head but it works.
Thanks for the replies again folks!!
Ironically, the tire shop did have the same tool and just couldn't get enough leverage between the cap and rim to pry the cap off. Almost like it was "super glued" on.
Also, thanks for the heads up on the bad batch of sensors. Will advise tire shop so they can look into getting me replacements---unless Ford is replacing them free of charge.
