- sga_jedExplorerI have a 2006 Expy and I tow a 2010 Keystone Laredo 291TG. The Laredo is 31' and weighs 6,400lbs. I invested in a ProPride hitch about two years ago and the combo tows great! The ProPride is a little expensive (approx $2k) but I would not tow without it.
Best wishes! - TerryallanExplorer II
SprinklerMan wrote:
Terryallan wrote:
SprinklerMan wrote:
I pull a 30 ft sunset creek with a v10 excursion . Its a 3/4 ton truck basically . My truck is rated for 10k towing , camper weighs 8400lbs loaded .I know its back there. What always concerns me when towing is braking , I can stop with the 3/4 tons brakes , I wouldnt trust a 1/2 ton vehicle with towing weight with family on board .
Again. Neither the brakes on your Excursion, OR a 1500 truck , are rated to stop the trailer. The brakes on the Ex are only rated to stop the GVW of the Ex. Not the TT. That's what the TT brakes do.
Don't be fooled in to thinkin a bigger truck is rated to stop a bigger tailer. It's not. Anything over the GVWR of the TV, the TT brakes have to stop.
They may not be rated to but they will , The brakes and calipers are bigger on my excursion vs my old f 150 , yes the ex has a greater curb weight . but it will stop both rather well with out the trailer brakes. Accidents happen , as well as mistakes , a friend had his trailer plug come loose on his tripple axle 5th wheel pulling with a f 350 dually , going down an good incline , he stopped safely , found a parts store spent the next 2 hours replacing all the brakes and front rotars. Bigger brakes , better stopping .
Overloaded barkes are overloaded brakes no matter what they are on. As for the down grade. I use very little brakes on a down grade. I let the engine hold it back, Touching them only briefly for turns. Sounds like he rode his all the way down. - SprinklerManExplorer
They may not be rated to but they will , The brakes and calipers are bigger on my excursion vs my old f 150 , yes the ex has a greater curb weight . but it will stop both rather well with out the trailer brakes. Accidents happen , as well as mistakes , a friend had his trailer plug come loose on his tripple axle 5th wheel pulling with a f 350 dually , going down an good incline , he stopped safely , found a parts store spent the next 2 hours replacing all the brakes and front rotars. Bigger brakes , better stopping . - Buck50HDExplorerThis one might be more of question of short wheelbase vs trailer length, rather than tongue weight vs GVWR. Depends on your threshold of comfort along with distance and type of terrain.
My opinion is 2k lb less trailer and 26-28' max based on towing a 6300 dry 26' with a standard 1/2 ton truck with 145" wb. It was great when conditions were favorable but when the wind picked up, not fun. - TerryallanExplorer II
linchat wrote:
Hello all, new to the forums and new to RVing. Have a small dimemna. We purchased Ford Expedition 2012 EL (131" Wheel) with Tow Package allow for 8900# towing. We are looking at Cougar 31SQB at 7200#.
Do you think it is a good marriage? Any thoughts? Thanks.
Personally I believe a 7200lb dry TT, with be too much for a 8900lb tw capacity. Unless you only load less than 1000lbs into the trailer, and less than 700lbs including the family into the EXpe. - linchatExplorerWell, I have been feeling I might be pushing it. Looking to see if I can pull another 1000# out of the TT looking at diff models. Problem is, finding something with good height in TT. I am tall, allot of TT's have low ceiling, the Cougars have decent height in it.
Looking for something with queen / bunks in separate rooms, good ceiling height, I suppose around 6200#.
Any idea's on models/ mfg that make TT's with good interior height at abour 28-30' long? - TerryallanExplorer II
Don't be fooled in to thinkin a bigger truck is rated to stop a bigger tailer. It's not. Anything over the GVWR of the TV, the TT brakes have to stop. - dodge_guyExplorer IIIs the 7200lbs dry weight or gross weight? If it is dry figure on adding 1200-1500lbs to the dry weight!
- SprinklerManExplorerI pull a 30 ft sunset creek with a v10 excursion . Its a 3/4 ton truck basically . My truck is rated for 10k towing , camper weighs 8400lbs loaded .I know its back there. What always concerns me when towing is braking , I can stop with the 3/4 tons brakes , I wouldnt trust a 1/2 ton vehicle with towing weight with family on board .
- Desert_CaptainExplorer III
linchat wrote:
When you say you can't / shouldn't is it safety, or damage to vehicle. Where are the concerns? Just trying to figure out biggest I can safely tow. Getting bigger is not ego related :), have 4 small kids.
Thanks.
Here is a quote from the Trailer Life Magazine 2012 Towing Guide:
"The gvwr figures are neither guideline nor estimates; they are limits, and there are numerous valid reasons the manufacturer arrived at these figures. If you think the figures are "close enough" or have a fudge-factor percentage built in, think again. Your warranty coverage, and your safety may be at risk."
Running at or near your rigs limits is, IMHO, a fools errand. There is simply no good reason to do so. That much trailer will probably have the tail wagging the dog in all but the best weather and flattest roads. This obviously is mere speculation on my part but I would urge caution. What is your TV's max payload and tow capacity? You will very likely exceed your GVR long before you get to the tow capacity even though you will probably be under your GCWR. :C
44,025 PostsLatest Activity: Feb 06, 2025
